Jan 15, 2024 10:41 AM UTC
Post Publishing Failed
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS16
How to get more info of failed Post Publishing job??
Here are the errors that I faced
Post Publishing Failed.
Error Creating EPMDocument.
GucioAnswer
Jan 15, 2024 1:43 PM UTC
Problem was with naming convention. At the very begining it was set as follow
                                               <post-publish name="number">{EPM_NUMBER}-PG</post-publish>
                                               <post-publish name="name">{EPM_NAME} (Publication Graphic)</post-publish>
but after some time user has changed into
                                               <post-publish name="name">{EPM_NUMBER} {EPM_NAME} (PG)</post-publish>
As a result BGMS shows error:
Nested exception is: wt.pom.UniquenessException: Publication Graphic - xxxxxxxxxxxxxxxxxx is not unique
jbailey
18-Opal
Jan 15, 2024 11:04 AM UTC
Did the initial publish succeed or fail?
avillanueva
23-Emerald II
Jan 15, 2024 1:35 PM UTC
Can you explain your rules and post the logs?
Gucio16-PearlAuthorAnswer
