I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
Pre-Upgrade WINDU Potential error " ObjectsInExternalOrgDT"
Here are the errors that I faced
Tue 5/14/24 13:27:35: WinDU has found conflicting object(s) which cannot be repaired automatically. Resolve these conflicts manually by renumbering the object or by changing the organization of the object.
Tue 5/14/24 13:27:35: The conflicting objects are listed for Site level and Organization level Migration respectively.
Tue 5/14/24 13:27:35: If the customer wants to move to Site level uniqueness, then there should not exist any conflicting objects for Site level Migration in the WinDU report.
Tue 5/14/24 13:27:35: If the customer wants to move to Org level uniqueness, then there should not exist any conflicting objects for Organization level Migration in the WinDU report.
Tue 5/14/24 13:27:35: If the report does not lists conflicting objects in Site or Organization level uniqueness section, then there are no conflicts in that section.
Tue 5/14/24 13:27:35: Find these object(s) logged in respective files in log directory or click the links below this log file.
Hi @KM_8552936 ,
I wanted to follow up with you on your post to see if your question has been answered. If so, please mark the reply as the Accepted Solution for the benefit of other members who may have the same question. Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
Thanks!
