Dear all,
I was running pre-upgrade mandatory WINDU task where I got some potential problems out of which few were corrupt records error. For example
============================================================================================================================= LifecycleTemplate IDA2A2 LifecycleTemplate Name Missing PhaseTemplate Object IDA2A2 ============================================================================================================================= wt.lifecycle.LifeCycleTemplate 9815 ENDITEM_LC(Iteration 1) wt.lifecycle.PhaseTemplate 9826 - - - wt.lifecycle.PhaseTemplate 9841 wt.lifecycle.LifeCycleTemplate 9889 ENDITEM_LC(Iteration 2) wt.lifecycle.PhaseTemplate 9901 - - - wt.lifecycle.PhaseTemplate 9913 ===================== SUMMARY ===================== Total records: 47 Corrupted records: 2
Can I delete these corrupted records? Will there be any issue created if I delete a row from my LifecycleTemplate table? Any suggestions on how to get rid of this error?
WINDU provides utilities to remove these corrupt records. Instead of manually deleting these records utility should be used.
