Preview Config.pro option
JonTribe
Hi all you PTC guru types...
Can anyone tell me, is there a setting in WC or a config.pro option that would automatically generate the preview viewable files on checkin to Windchill?
It would be nice to be able to use the standard 'Auto check in' function instead of the 'custom check in' with all the added clicks needed.
We are using WF3 M240 and WC9.1 M060.
Any advice/ideas would be much appreciated.
Thanks in advance...
You can configure a ProE Worker + Cad Agent on the server.
See Windchill® System Administrator's Guide (Chapter "Working Agent") and ProductView® Adapters Installation and Configuration Guide (Chapter "Introduction to the ProductView Adapter for Pro/ENGINEER").
The configuration process is quite straightforward and takes ~15 mins.
After the server is configured, all ProE data will be automatically visualized after CheckIn.
