Can someone help me out with the following issue?
I have two CAD Workers for Publishing configured in my PDM Link instance one for Creo Parametric and the other for Inventor.
I want to configure in such a way that publishing needs to be prioritised depending on the number of objects qued up, the higher the que the CAD worker needs to publish those specific tyoe of files.
Thanks in advance.
Amar.
create three Publisher Queues (PublisherQueue1, PublisherQueue2, PublisherQueue3). Then should these two workers parallel be filled with new jobs.
Or do you mean setting the job priority dependent where the job comes from? Then have a look at the case:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS28472
Björn
Björn
Thanks Bjorn,
Also can you let me know what are the ways to assign Parallel print jobs?
Amar.
No, sorry. I'm not familiar with the printing function. But I would guess there is also a possibility similar to the worker queues.
Björn
