Pro/E to Windchill chekin of part
snehalbirajdar
Hi all,
I am trying to checkin a part from PRO/E Wildfire 3.0to Windchill PDMLink 8.0(M040). OOTB this will be checked in as a type of WTPart. Instead of thatwhen a part is checked in to Windchill I want its type to be a sub type of WTPart which I have created in Windchill. Also there are some IBA's accosiated to this sub type in Windchill. I want these IBA values to be populated when the part is checkedin to subtype.
Has any one worked on this before.
Thanks in Advance.
we've created a custom class that will type the part during
auto-creation. where would the IBA values come from?
martin
Snehal Birajdar wrote:
> Hi all,
> I am trying to checkin a part from PRO/E Wildfire 3.0 to Windchill
> Instead of that when a part is checked in to Windchill I want its type
> these IBA values to be populated when the part is checked in to subtype.
> Thanks in Advance.
> -----End Original Message-----
Martin,
When you check in a part from PRO/E to Windchill you have to set parameters
in PRO/E (Tools>Parameter) and this parameter name is mapped to Windchill
IBA through iba.properties.
The subtype of WTPart has this IBA attached. When part is checked in from
PRO/E this IBA should be populated with the parameter value from PRO/E.
Thanks & Regards,
Snehal
