Pro/INTRALINK 3.x folder-level where-used
JohnMacpherson
We've been asked the following by one of our end-users:
"Do you know if we can generate a report or some script in Oracle to
know if the parts in folder eng_part_lib has use."
Does anyone have a solution for this other than running a where-used
report on every object in the folder through the UI? Any suggestions
would be appreciated. Thanks.
John M.
You can accomplish this with a Pro/INTRALINK Toolkit application. You can find all objects within a folder and then run a where used query on each of them.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
