Brian
We had one user that had the same problem, there was some sort of
corruption in the .proi, so I simply deleted it, and let IntraLINK
create a new one. The problem has not repeated itself since.
The information contained in or attached to this email is intended only
for the use of the addressee. If you are not the original intended
recipient of this email, or a person responsible for delivering it to
the original intended recipient, you are strictly prohibited from
disclosing, copying, distributing or retaining this email or any part of
it. This email may contain information which is confidential and/or
covered by legal, professional or other privilege under applicable law.
If you received this email in error, please notify the sender
immediately by return email and destroy all copies of the information
contained in or attached thereto. Thank you for your cooperation.
The views expressed in this email are not necessarily the views of CFM
Corporation or any of its divisions or affiliates, and the said entities
and their respective directors, officers and employees make no
representation, nor accept any liability, regarding its accuracy or
completeness, unless expressly stated to the contrary.
