ProE without PDMLink
EricHuffman
2-Explorer
Gurus,
I am using Wildfire4 with PDMLink9 most of the time. The other time I am
supporting a customer who is still on Wildfire3 with no PDM. Every time
I launch W3 it wants to register the server; is there is a config.pro
option that I can add to my wildfire3 config so it will quite asking me
to register the PDMLink server?
Eric
REM set the .wf folder location to c:\workspaces
@set PTC_WF_ROOT=c:\wf4workspaces
Set that in the WF3 batch file to some other folder.
On 03/05/10 14:04, Huffman, Eric wrote:
> Gurus,
2 things you can do:
1. add "dm_remember_server no" to your config.pro
2. make sure you don't have any config options such as pro_format_dir
that have a value starting with wtpub:// or ilcs://
> Thanks,
> Eric
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
Eric,
I use the following lines in a startup batch file:
set PTC_WF_ROOT=%userprofile%\My Documents\ProE\PTC\.wf
set PTC_WF_CACHE=%userprofile%\My Documents\ProE\PTC\.wf
You can create a duplicate startup file that doesn't contain these
settings or has them commented out. In addition, if you have config
files with directory settings for Windchill, you can copy these with
your startup batch files accordingly prior to launching Wildfire.
James
Not applicable
(To:EricHuffman)
Dan Harlan
