Probatch option "Send to Windchill" is greyed out.
GM_11078588
2-Explorer
I am using Windchill PDM Essentials Release 11.2 and Datecode with CPS 11.2.0.1
I cannot select the output option "Send to Windchill" when using probatch (CREO distributed batch).
Here are the errors that I faced
the option is greyed out.
6 REPLIES 6
I am unfamiliar with this feature and where it is. Can you send screen shots or describe more?
It is inside the probatch file.
HelesicPetr
(To:GM_11078588)
Hi @GM_11078588,
Anurag
HelesicPetr
(To:GM_11078588)
Hi @GM_11078588
I guess that you need to be in a right group that allows this feature. It is not available if the admin is not in specific user group.
PetrH
Yashraj_R
(To:GM_11078588)
Hi any update on the solution?
