Problem with Change management
pshetty-2
9-Granite
I am facing an error while executing an wokflow..
ERROR-
Errors: Can't execute: bad workflow expression
(wt.workflow.definer.definerResource/19) wt.workflow.WfException: Can't execute: bad workflow expression
at wt.workflow.definer.WfExpression.execute(WfExpression.java:882)
at wt.workflow.engine.WfExecutionObject.evaluateExpression(WfExecutionObject.java:1928)
at wt.workflow.engine.WfActivity.complete(WfActivity.java:1047)
at wt.workflow.engine.StandardWfEngineService.complete(StandardWfEngineService.java:3767)
I just wants to know the reason when we get such kind of exceptions....
Prashant Shetty .
Go green .
You have a transition or expression robot that did not compile (check
syntax) or other error at that point in your workflow.
