Version: Windchill 12.0
Use Case: Hello all, I have a question in relation to Process Links. You can pick many different options in Link Properties, but there meaning7consequense of it is not described anywhere E.g. Suspend Terminate Abort
Description:
I need to "de-activate" the node " Test PPAP Samples, when the node "Evaluate Customer response for Samples" is routed to New Samples (Orange Arrow)
But when the Green arrow link fires to start up the node "Test PPAP Samples" it must be activated/Resumed again.
What should I select in the Link Property for the Orange arrow to make this work?
If you need clarification on my issue, just ask.
Hi KNielsen,
Thank you for your question.
Best Regards,
Vivek N
Community Moderation Team
