Process Plan is constantly checked out - can that be changed?
TommyRasmussen
11-Garnet
Version: Windchill 13.0
Use Case: Working with Process Plans
Description:
The Process Plan is automatically checked out e.g. when i allocate a part to an operation.
How do I configure the system so only the operation object is checked out in that case?
Hi @TommyRasmussen
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Hi Catalina
The use case is that I move allocated part(s) from one operation to another...
It will automatically check out both operations - that is expected.
But the Process Plan is also checked out....
Can I configure Windchill to avoid that?
