I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
The process procedure ZZ_GC_0000035709_INDEX failed when publishing a single procedure. No error message was seen. There was a return message in the log: no need to process the request.
作业日志
2023-12-4 8:09:26:开始作业: 发布来源 - FA7R系列(Ⅸ线/34岗)工艺规程(Released)_INDEX, EU.23
2023-12-4 8:09:26:产生 temp dir :/ptc/Windchill/tmp/pubtemp/publish1072540746031180165.tmp
2023-12-4 8:09:26:启动: 发布来源 - FA7R系列(Ⅸ线/34岗)工艺规程(Released)_INDEX, EU.23
2023-12-4 8:09:26:创作应用程序: Arbortext Editor
2023-12-4 8:09:26:Arbortext 装配转换
2023-12-4 8:09:26:产生 temp dir :/ptc/Windchill/tmp/pubtemp/publish571111986399022420ed
2023-12-4 8:09:26:无需处理请求
2023-12-4 8:09:26:结束发布:发布来源 - FA7R系列(Ⅸ线/34岗)工艺规程(Released)_INDEX, EU.23
2023-12-4 8:09:26:删除 temp dir: /ptc/Windchill/tmp/pubtemp/publish571111986399022420ed
2023-12-4 8:09:26:Arbortext 装配,已处理 1 个组件
2023-12-4 8:09:26:结束作业 (出现错误): 发布来源 - FA7R系列(Ⅸ线/34岗)工艺规程(Released)_INDEX, EU.23
2023-12-4 8:09:26:Release Complete 事件已经分派
2023-12-4 8:09:26:删除 temp dir: /ptc/Windchill/tmp/pubtemp/publish1072540746031180165.tmp
Translated the text from Simplified Chinese to English using google translate
Subject - 工艺规程在WVS作业监视器里发布失败
Body- 工艺规程ZZ_GC_0000035709_INDEX单个规程进行发布表示时失败,未见到有报错提示,看到日志有个返回:无需处理请求。
Job log
2023-12-4 8:09:26: Start operation: Release source - FA7R series (Line IX/34 posts) Process Specification (Released)_INDEX, EU.23
2023-12-4 8:09:26: Generate temp dir:/ptc/Windchill/tmp/pubtemp/publish1072540746031180165.tmp
2023-12-4 8:09:26: Start: Release source - FA7R series (Line IX/34 posts) Process Specification (Released)_INDEX, EU.23
2023-12-4 8:09:26: Authoring application: Arbortext Editor
2023-12-4 8:09:26:Arbortext assembly conversion
2023-12-4 8:09:26: Generate temp dir:/ptc/Windchill/tmp/pubtemp/publish571111986399022420ed
2023-12-4 8:09:26: No need to process the request
2023-12-4 8:09:26: End of release: Release source - FA7R series (Line IX/34 posts) Process Specification (Released)_INDEX, EU.23
2023-12-4 8:09:26: Delete temp dir: /ptc/Windchill/tmp/pubtemp/publish571111986399022420ed
2023-12-4 8:09:26: Arbortext assembly, 1 component processed
2023-12-4 8:09:26: End of operation (error occurred): Release source - FA7R series (Line IX/34 posts) Process Specification (Released)_INDEX, EU.23
2023-12-4 8:09:26:Release Complete event has been dispatched
2023-12-4 8:09:26: Delete temp dir: /ptc/Windchill/tmp/pubtemp/publish1072540746031180165.tmp
Hi @QM_8669844
It is common information when the object is send to publish queue even though there is nothing to visualize.
In that situation, the request is processed with error and information that there is nothing to do.
What is your question? I missed it.
PetrH
