Product Strcuture and Change Management size survey
JeffZemsky
Good afternoon.
We are doing a survey on product structure and change management data set sizes. Your participation is greatly appreciated. (Note: If you are a Technical Committee member you can ignore this is the same one)
Product and Change Management survey
Jeff Zemsky
This time with a better link
Survey link
Jeff Zemsky
The Survey is going to close on Wednesday, December 22 -
Your participation and support is appreciated (and an easy way to get your needs quantified)
Thank you.
In Reply to Jeff Zemsky:
Survey link
Jeff Zemsky
Jeff Zemsky
