Products missing after Rehost
bschmidt-2
Hi all,
we created a test system and tried to rehost our production system (Windchill 10.2 M030 CPS03).
It worked fine with the user data (LDAP import successful) but we are missing all our products and objects. We can only see the newly created product.
Please see attached screenshot.
Does anyone have a hint what could have gone wrong during rehosting? Did anyone experience the same behavior?
Thanks in advance!
Benjamin
TomU
(To:bschmidt-2)
The fact that Windchill starts up successfully makes me think the Rehost utility worked fine.  I really question if the database was imported correctly.  The Rehost utility doesn't make changes to existing products or libraries.  It's basically changing server names, file paths, passwords, etc.  If the rehosted system fires up correctly, then what you see when you log it is what exists in the database.
Are you allowed access directly to the database?  If so, try querying for the products and libraries:
select * from PDMLinkProduct
select * from WTLibrary
10 REPLIES 10
TomU
(To:bschmidt-2)
Did you copy your production database to your test system (and import it) before running the Rehost utility?
bschmidt-2
(To:TomU)
Expdp and impdp were called during the rehosting.
We did the following steps:
  1. export ldap
  2. import ldap
  3. expdp
  4. impdp
  5. copy vaults
TomU
(To:bschmidt-2)
What version of the Rehost utility are you using?
Are you positive the database import actually worked?  (Maybe do a row count on a few of the larger tables and make sure they agree with production.)
I'm assuming you ran the other required Rehost tasks after step 5 above - InfoEngine, Apache, Database, and Vault...
bschmidt-2
(To:TomU)
RehostingUtility 10.2 M010 it is.
And yes, we ran the other tasks afterwards.
Here's the logfile:
WARN  [Echo]: ***************************************************************
WARN  [Echo]: **  Starting Rehost Utility 3.0 M010 B05  20160916 1631 (16) **
WARN  [Echo]: modules=rehost.firstrun
INFO  [DBConnectionValidator]: RehostProject: OS Name: Windows Server 2012 R2 windows:true prop dir:D:\install\MED-61138-CD-RehostingUtility_102_M010\conf\rehost.properties
INFO  [DBConnectionValidator]: Log may contain passwords? false
INFO  [DBConnectionValidator]: Properties for Task:
INFO  [DBConnectionValidator]: * Rehost Parameter:rehost.log.passwords=false
* Rehost Parameter:test.prop.values.only=false
target.db.hostname=srv-test.smb.lan
target.db.jdbc.database=
target.db.password=*******
target.db.port=1521
target.db.serviceName=oratest
target.db.username=orauser
target.db.vendor=oracle
INFO  [DBConnectionValidator]: Connecting to jdbc:oracle:thin:@srv-test.smb.lan:1521:oratest
INFO  [DBConnectionValidator]: Successfully connected to the database.
WARN  [Echo]: InfoEngine,Database
INFO  [BackupTask]: RehostProject: OS Name: Windows Server 2012 R2 windows:true prop dir:D:\install\MED-61138-CD-RehostingUtility_102_M010\conf\rehost.properties
INFO  [BackupTask]: Log may contain passwords? false
INFO  [BackupTask]: Properties for Task:
INFO  [BackupTask]: * Rehost Parameter:rehost.log.passwords=false
* Rehost Parameter:target.directory.ldap=D:\ptc\Windchill_10.2\WindchillDS
rehost.useCase=rehost.firstrun
target.db.port=1521
INFO  [BackupTask]: Rehost home directory is D:\install\MED-61138-CD-RehostingUtility_102_M010
INFO  [BackupTask]: Backing up rehost configuration to D:\install\MED-61138-CD-RehostingUtility_102_M010\backups\rehost.firstrun_20160916_1631
INFO  [BackupTask]: Discovered tasks: InfoEngine,Database for scenario: rehost.firstrun
INFO  [BackupTask]: Enabling ldap backup beause of task InfoEngine
INFO  [BackupTask]: Adding tables to backup set: Repository,RemoteObjectId,FvHost,WTProcessStep,CollaborationInfo
INFO  [BackupTask]: Properties for exporting LDAP:
INFO  [BackupTask]: target.directory.ldap=D:\ptc\Windchill_10.2\WindchillDS
target.ldap.baseDn=cn=configuration,cn=Windchill_10.2,o=ptc
target.ldap.hostname_NO_SUFFIX_=srv-test.smb.lan
target.ldap.password_NO_SUFFIX_=******
target.ldap.port_NO_SUFFIX_=389
target.ldap.username_NO_SUFFIX_=cn=Manager
INFO  [BackupTask]: Running command: D:\ptc\Windchill_10.2\WindchillDS\server\bat\export-ldif --ldifFile D:\install\MED-61138-CD-RehostingUtility_102_M010\backups\rehost.firstrun_20160916_1631\backup.ldif --backendID userRoot --appendToLDIF --hostName srv-test.smb.lan --port 4444 --bindDN cn=Manager --bindPassword ****** --trustAll --noPropertiesFile
INFO  [BackupTask]: ** command output **
Export task 20160916163134037 scheduled to start immediately
[16/Sep/2016:16:31:33.990 +0200] severity="NOTICE" msgCount=0 msgID=9896349 message="Export task 20160916163134037 started execution"
[16/Sep/2016:16:31:33.990 +0200] severity="INFORMATION" msgCount=1 msgID=10487422 message="Exporting to D:\install\MED-61138-CD-RehostingUtility_102_M010\backups\rehost.firstrun_20160916_1631\backup.ldif"
[16/Sep/2016:16:31:33.990 +0200] severity="NOTICE" msgCount=2 msgID=8847447 message="Exported 372 entries and skipped 0 in 0 seconds (average rate 11625,0/sec)"
[16/Sep/2016:16:31:33.990 +0200] severity="NOTICE" msgCount=3 msgID=9896350 message="Export task 20160916163134037 finished execution"
Export task 20160916163134037 has been successfully completed
** End command output **
Command successful
INFO  [BackupTask]: Backing up database tables: [CollaborationInfo, Repository, FvHost, WTProcessStep, RemoteObjectId]
INFO  [BackupTask]: Connecting to jdbc:oracle:thin:@srv-test.smb.lan:1521:oratest
INFO  [BackupTask]: Ignore following error message if backup table already existed.
INFO  [BackupTask]: ORA-00955: Es gibt bereits ein Objekt mit diesem Namen
INFO  [BackupTask]: backup is complete
WARN  [Echo]: EXEC: rehost.firstrun cur:InfoEngine
WARN  [Echo]: rehostTaskName=rehost
WARN  [Echo]: taskCMD=${taskCMD}
WARN  [Echo]: StartProcessCMD=${StartProcessCMD}
INFO  [IeRehosterTask]: RehostProject: OS Name: Windows Server 2012 R2 windows:true prop dir:D:\install\MED-61138-CD-RehostingUtility_102_M010\conf\rehost.properties
INFO  [IeRehosterTask]: Log may contain passwords? false
INFO  [IeRehosterTask]: Properties for Task:
INFO  [IeRehosterTask]: * Rehost Parameter:rehost.log.passwords=false
* Rehost Parameter:source.directory.windchill=D:\ptc\staging\Windchill_P
* Rehost Parameter:target.directory.windchill=D:\ptc\Windchill_10.2\Windchill
* Rehost Parameter:target.wc.hostname=srv-test.smb.lan
cluster.slave.rehost=false
target.ldap.filter=(objectClass=*)
INFO  [IeRehosterTask]: Updating windchill host? true
INFO  [IeRehosterTask]: Updating application name? false
INFO  [IeRehosterTask]: Keeping previous domain?: true sourceAdapter: lan.smb.srv-test targetAdapter: lan.smb.srv-test
INFO  [IeRehosterTask]: Found repository srv-test.smb.lan
INFO  [IeRehosterTask]: not changing domain for repository srv-test.smb.lan
INFO  [IeRehosterTask]: Found repository Ldap.smb.lan
INFO  [IeRehosterTask]: not changing domain for repository Ldap.smb.lan
INFO  [IeRehosterTask]: Found repository EnterpriseLdap.smb.lan
INFO  [IeRehosterTask]: not changing domain for repository EnterpriseLdap.smb.lan
INFO  [IeRehosterTask]: Keeping home directory: false targetWindchillDir: D:/ptc/Windchill_10.2/Windchill sourceWindchillDir: D:/ptc/staging/Windchill_P
INFO  [IeRehosterTask]: Changing LDAP - Source: d:/ptc/staging/windchill_p Target: D:/ptc/Windchill_10.2/Windchill
INFO  [IeRehosterTask]: Using props for lan.smb.srv-test
INFO  [IeRehosterTask]: ** Changing lan.smb.srv-test.servlet.administration.baseUri=ldap://srv-test.smb.lan:389/dc=srv-test,dc=smb,dc=lan,cn=configuration,cn=Windchill_10.2,o=ptc to lan.smb.srv-test.servlet.administration.baseUri=ldap://srv-test.smb.lan:389/dc=srv-test,dc=smb,dc=lan,cn=configuration,cn=Windchill_10.2,o=ptc
INFO  [IeRehosterTask]: ** Changing lan.smb.Ldap.java.naming.provider.url=ldap://srv-test.smb.lan:389 to lan.smb.Ldap.java.naming.provider.url=ldap://srv-test.smb.lan:389
INFO  [IeRehosterTask]: ** Changing lan.smb.EnterpriseLdap.java.naming.provider.url=ldap://srv-test.smb.lan:389 to lan.smb.EnterpriseLdap.java.naming.provider.url=ldap://srv-test.smb.lan:389
INFO  [IeRehosterTask]: Changing LDAP server from ldap://srv-test.smb.lan:389 to ldap://srv-test.smb.lan:389
INFO  [IeRehosterTask]: Changing Java RMI Server Host from srv-test.smb.lan to srv-test.smb.lan
INFO  [IeRehosterTask]: Changing Wt RMI Server Host from srv-test.smb.lan to srv-test.smb.lan
INFO  [IeRehosterTask]: ** command output **
Default product root=D:\ptc\Windchill_10.2\Windchill\bin\..
java -cp "D:\ptc\Windchill_10.2\Windchill\bin\..\codebase;D:\ptc\Windchill_10.2\Windchill\bin\..\codebase\WEB-INF\lib\*;D:\ptc\Windchill_10.2\Windchill\bin\..\lib\*" com.ptc.windchill.structconf.StructConfManager -r "D:\ptc\Windchill_10.2\Windchill\bin\.." -t codebase/wt.properties -s wt.federation.ie.ldapServer=ldap://srv-test.smb.lan:389 -s java.rmi.server.hostname=srv-test.smb.lan -s wt.rmi.server.hostname=srv-test.smb.lan
Command successful
INFO  [IeRehosterTask]: Command to update IE struct properties: xconfmanager -s ie.ldap.managerDn=cn=Manager -s ie.ldap.managerPw=****** -s ie.ldap.serverHostName=srv-test.smb.lan -s ie.ldap.serverPort=389 -t codebase/WEB-INF/ieStructProperties.txt
java -cp "D:\ptc\Windchill_10.2\Windchill\bin\..\codebase;D:\ptc\Windchill_10.2\Windchill\bin\..\codebase\WEB-INF\lib\*;D:\ptc\Windchill_10.2\Windchill\bin\..\lib\*" com.ptc.windchill.structconf.StructConfManager -r "D:\ptc\Windchill_10.2\Windchill\bin\.." -s ie.ldap.managerDn=cn=Manager -s ie.ldap.managerPw=****** -s ie.ldap.serverHostName=srv-test.smb.lan -s ie.ldap.serverPort=389 -t codebase/WEB-INF/ieStructProperties.txt
Command successful
INFO  [IeRehosterTask]: Updating credentials map
INFO  [IeRehosterTask]: Checking property: mapcredentials.admin.adapters original_value: lan.smb.Ldap^cn=Manager^encrypted.lan.smb.Ldap.cn=Manager;lan.smb.EnterpriseLdap^cn=Manager^encrypted.lan.smb.EnterpriseLdap.cn=Manager
INFO  [IeRehosterTask]: Removing the previous values
java -cp "D:\ptc\Windchill_10.2\Windchill\bin\..\codebase;D:\ptc\Windchill_10.2\Windchill\bin\..\codebase\WEB-INF\lib\*;D:\ptc\Windchill_10.2\Windchill\bin\..\lib\*" com.ptc.windchill.structconf.StructConfManager -r "D:\ptc\Windchill_10.2\Windchill\bin\.." --undefine mapcredentials.admin.adapters
Command successful
INFO  [IeRehosterTask]: adding new credentials for adapter: lan.smb.Ldap
INFO  [IeRehosterTask]: adding new credentials for adapter: lan.smb.EnterpriseLdap
INFO  [IeRehosterTask]: Checking property: mapcredentials.nonprivileged.adapters original_value:
INFO  [IeRehosterTask]: Adding the new values
WARN  [Echo]: EXEC: rehost.firstrun cur:Database
INFO  [DatabaseRehostTask]: RehostProject: OS Name: Windows Server 2012 R2 windows:true prop dir:D:\install\MED-61138-CD-RehostingUtility_102_M010\conf\rehost.properties
INFO  [DatabaseRehostTask]: Log may contain passwords? false
INFO  [DatabaseRehostTask]: Properties for Task:
INFO  [DatabaseRehostTask]: * Rehost Parameter:rehost.log.passwords=false
target.db.port=1521
INFO  [DatabaseRehostTask]: DB property update command: xconfmanager -s wt.pom.dbUser=orauser -s wt.pom.dbPassword=******* -s wt.pom.serviceName=srv-test.smb.lan:1521:oratest -s wt.pom.jdbc.service=oratest -s wt.pom.jdbc.host=srv-test.smb.lan -s wt.pom.jdbc.port=1521 -t db/db.properties
INFO  [DatabaseRehostTask]: Connecting to jdbc:oracle:thin:@srv-test.smb.lan:1521:oratest
INFO  [DatabaseRehostTask]: Source AppName: Windchill Target AppName: null
INFO  [DatabaseRehostTask]: Not changing local repository name: srv-test.smb.lan
INFO  [DatabaseRehostTask]: No Repositories will be renamed
WARN  [Echo]: running /c D:\ptc\Windchill_10.2\Windchill/bin/xconfmanager -p
INFO  [FinalizeTask]: RehostProject: OS Name: Windows Server 2012 R2 windows:true prop dir:D:\install\MED-61138-CD-RehostingUtility_102_M010\conf\rehost.properties
INFO  [FinalizeTask]: Log may contain passwords? false
INFO  [FinalizeTask]: Properties for Task:
INFO  [FinalizeTask]: * Rehost Parameter:rehost.keystore.clear=false
Maybe you can find the answer
TomU
(To:bschmidt-2)
I don't see the database export and import tasks listed.  Do you run those manually before running the Rehost tool?  Maybe you could share your projects.properties file.
bschmidt-2
(To:TomU)
Yes, we did run expdp and impdp before starting the Rehosting Utility.
Projects.properties:
# This file is used to define sets of tasks to be run in sequence.
# Property rehost.useCase in rehost.properties should be set to match the
#   property name listing the desired set of tasks.
# These tasks should be run with Apache and the Windchill MethodServer stopped, and the database running:
# * Apache: Propagate Apache configuration changes
# * ChangeHome: Update Windchill and Apache for a new location - the Apache task needs to run afterwards to propagate the Apache changes
# * Cluster: Update Windchill properties specific to a clustered environment
# * ContainerTemplate: Copy container templates to a stubbed vault to allow it to be used in Upgrade testing
# * Copy: Copy files from staging to target location - needs to be run first for new environments
# * Database: Update Windchill's database connection
# * InfoEngine: Update Windchill's LDAP server connection(s), and update LDAP properties
# * QueueMgmt: Stop, start, or clear queues
# * Script: Allows for user defined tasks
# * Solr: Update Solr settings
# * Vault: Update FileVault configuration, and copy vault content
# * WVSAgent: Update WVS agent configuration
# * WVSWorker: Update WVS worker configuration
# This task should be run after copying lib/wcRehost.jar to <Windchill_Home>/lib/ then starting Apache, and the Windchill MethodServer
# * SelectiveContent: Copies selected vault content to the new location
# These are the standard sets of tasks for these functions:
# rename=InfoEngine,Database,Apache
# rehost=InfoEngine,Database,Apache,Vault
# clone=Copy,InfoEngine,Database,Apache
# move=Copy,ChangeHome,InfoEngine,Apache
rehost.firstrun=Vault,InfoEngine,Apache,Database
TomU
(To:bschmidt-2)
bschmidt-2
(To:TomU)
Hi guys,
thanks for all the help and hints! We solved the issue 😉
I was a little bit confused by my own rehosting. Tom's hint lead us to the solution.
We run the selects and found out that there are 60 products in production system, but only one(!) in our test system.
We saw that there are two different users on the test database. PDMLINK and ORAUSER. So we connected as the other user and the select returned 60 products. So we changed the db.properties and fixed some "FILENAMEUSN_SEQ" and "STREAMID_SEQ" errors and voilá: Windchill was up and running 😄
Again, thanks for all!
Hopefully PTC is reading this...
I absolutely love what the Re-host utility brings to the table - and applaud PTC for developing it.  I've finally become relatively expert using it.
But, the documentation is extremely hard to follow.  It takes extreme perseverance to be able to get from the documentation what to actually do and how to do it.  The people writing it really tried - you can see that.  Just needs some more attention actually sitting with someone trying to follow it.  There is so much in the guide about the advanced functionality (e.g. scripting) but it's very hard to get to the point where a very bare-bones basic re-host process is working.
Mike - It is being read and passed along 🙂
Tom Uminn‌ thanks for your work.
Best,
Toby
