Sure ... anything is possible if you try : )
Here is a little snipit out of the batch file I created a few month ago, it compares the date code on the sever with te date code on the local machine.if the date codes don't match I prompt the user to enter their password and the latest date code will then be installed that night in a scheduled task... basically antother batch file that gets kicked off at 11:30 pm.
In that batch file I am sure you can rename the .proi folder. I'm not exactly sure what the dos command would be but it can be done! Heres a link to a dos help page
http://www.computerhope.com/jargon/i/intecomm.htmexperiement around,create a directory and follow the examples on this site when you have the technique down, add it to a simple batch file and make sure it still works. It may take a few tries but you'll figure it out.
Dave
