Hello everyone,
i need to programmatically set the "Disable Check out on the fly" preference.
I have found PreferenceHelper class used to retrieve the value, any correspondents class to set the value ?.
Thank you
Take a look at the methods (depending on the type of the preference):
wt.preference.PreferenceHelper.service.setValue(...)
Hi Florent,
classical Columbus egg.
I will let you know when i try.
Thank you
