Version: Windchill 11.1
Use Case: I've got reports that show the relationship between Promotion Requests and various objects.
Description:
I've got reports that show the relationship between Promotion Requests and various objects.The reports for Promotion Requests to WT Parts and Promotion Requests to CAD Documents, work fine, showing the iteration of the object released by the Promotion Request. However the report to show Promotion Requests to Documents doesn't show the correct iteration that was released, for example version 1.6 was released by the Promotion Request, issue 1.1 is showing against it on the report. The object type is the only difference between them. I've tried using latest iteration, but when I put that filter on it then just doesn't show that object on the report.
Anybody got any ideas?
QML of report attached
