Hello All,
I need help with another part of my promotion workflow. I usually assign several users to a single role. All must approve, but I want the workflow to reject if only one user rejects. Currently the workflow requires a reject vote from all the users.
Thanks in advance, Kathy
Hi Kathy,
There would be customized code need to add in the current workflow of Promotion Request. You can open a case with PTC Tech support so they will help you regarding this.
Hello All,
I was able to add a sycronize bot to my workflow to achive the desired result - thanks PTC! If anyone is interested I would be delighted to share.
Kathy
HI
I am also looking for similar worfkow,
Is it possible for you to share the details and workflow.?
Thanks in advance.
Regards
Giridhar
Please share with me also. Even I have the similar requirement. It will be great help, if you can share the workflow with us.
hello, cathy
can you share this solution to me? thank you advance.
