Publish - CAD Worker
Amirtharaj_K
Hi Guys,
CAD worker is running it's can't publish and if i go with manual representation it's published.
I want automatic publish.
AJ
Log:
10 Feb, 2024 8:47:42 PM:Start Store Preconverted Viewable Files
10 Feb, 2024 8:47:42 PM:Retrieving Additional Files
10 Feb, 2024 8:47:43 PM:No Thumbnail Created by Server
10 Feb, 2024 8:47:43 PM:WARNING: Unable to generate server thumbnail
10 Feb, 2024 8:47:43 PM:Uploading Files
10 Feb, 2024 8:47:43 PM:End Store Preconverted Viewable Files: 5 Files
10 Feb, 2024 8:47:43 PM:remove temp dir: C:\ptc\Windchill_12.1\Windchill\temp\pubtemp\publish7529873756576979549edz
10 Feb, 2024 8:47:43 PM:End: CAD Part  - 0000000042.prt, , A.1
10 Feb, 2024 8:47:43 PM:Representation Name: default
10 Feb, 2024 8:47:43 PM:Check for out of date Representations
10 Feb, 2024 8:47:43 PM:Number of Representations marked as out of date: 0
10 Feb, 2024 8:47:43 PM:End Job: CAD Part  - 0000000042.prt,  A.1
10 Feb, 2024 8:47:43 PM:Publish Complete event dispatched
10 Feb, 2024 8:47:43 PM:remove temp dir: C:\ptc\Windchill_12.1\Windchill\temp\pubtemp\publish3845098295940584910.tmp
Dobi
(To:Amirtharaj_K)
What do your publish rules look like? That's where you ought to have call outs for what triggers you want to initiate publishing.
Amirtharaj_K
(To:Dobi)
Thanks for the replay @Dobi
For example, when I go with CAD CAD-centric approach I use CAD software to check in right. There we have a 3 options Model | Viewable | Model & Viewable
If I select Model means it's published, but if I select Model & Viewable means I got an error like in the above one.
Aj
Dobi
(To:Amirtharaj_K)
On our end we mostly use non-Creo so that mechanism isn't an option for us 🙂
CS49107 goes over what the custom check-in options do.
Check-in models just checks in the native model as the content associated to the CAD document. There is no viewable generation per se unless in your publish rules you have a <check-in> trigger.
Check-in models and viewables generates the thumbnail client-side for all modified models... Are you models modified? From the looks of the log, there isn't an out of date representation.
Do you have CAD workers running to publish viewables, PDFs, etc.?
