I'm working with 11 F000, MPMLink, and ESI to publish Process Plans to SAP. When Windchill generates the ESI Response, it only includes newly created reference document links to process plan operations. In other words, if a reference document existed prior to changing the operation, or is removed from an operation, no link is published. Therefore, ESI is not removing the link, and the document PRT references become additive on the SAP side.
I did find a preference to render unchanged objects, but then it publishes all documents with a create link and adds multiple links on the SAP side.
I've filed a support request, but thought I'd reach out to the community for any experience with this issue.
Does anyone successfully publish PRT document links to routing operations in SAP AND remove them on changes? If so, what am I missing?
Casey
