I am having a strange issue with publishing Office Word documents that contain an A3. It is happening on one system and cannot be reproduced by PTC. We are using Office 365 and using the MS Office to publish NOT Adobe. The recipe is OOTB and worker is installed on Windchill server. Publishing seems to work fine for all word documents except the ones containing an A3 page. I am attaching a sample doc that fails publishing.
Can you please elaborate what strange issue you are observing ? as well what is version of Creo View Adapter are you using.
Ideally it would be good if you raise Tech Support case with PTC.
Thank You,
-Varad
The issue is that publishing fails. We are using the latest available version of the adapters. We have logged a call with PTC but have had no success as they cannot reproduce. The error is:
04/05/2021 2:03:20 PM:Start Job: (A.R.) QMS - D1027330, Windchill_Admin_01, A.7
04/05/2021 2:03:20 PM:make temp dir d:\ptc\Windchill_11.2\Windchill\temp\pubtemp\publish2408785347088885520.tmp
04/05/2021 2:03:20 PM:Start: (A.R.) QMS - D1027330, Windchill_Admin_01, A.7
04/05/2021 2:03:20 PM:Transferring Files to: d:\ptc\Windchill_11.2\Windchill\temp\pubtemp\publish2408785347088885520.tmp
04/05/2021 2:03:20 PM:Number of Files Transferred: 1
04/05/2021 2:03:20 PM:Document Conversion for File: Windchill_Admin_01.docx
04/05/2021 2:03:20 PM:Added request to OFFICE queue
04/05/2021 2:03:20 PM:No available connected worker
04/05/2021 2:03:20 PM:Starting new worker XXXXX-XXX.XXXX,local--OFFICE:1, attempt 1 of 3
04/05/2021 2:03:22 PM:Job 3 submitted to worker: XXXXX-XXX.XXXX,local-OFFICE:1
04/05/2021 2:03:22 PM:LOGID: worker_37.log
04/05/2021 2:03:22 PM: Publishing document
04/05/2021 2:03:26 PM:Failed to publish document file "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01.docx" to "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01_docx.pdf"
04/05/2021 2:03:26 PM:Document Processing Returned: $ERROR$ Failed to publish document file "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01.docx" to "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01_docx.pdf"
04/05/2021 2:03:26 PM:CadAgent Returned: $ERROR$ Failed to publish document file "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01.docx" to "d:/ptc/Windchill_11.2/Windchill/temp/pubtemp/publish2408785347088885520.tmp/Windchill_Admin_01_docx.pdf"
04/05/2021 2:03:26 PM:End (with Error): (A.R.) QMS - D1027330, Windchill_Admin_01, A.7
04/05/2021 2:03:26 PM:End job (with error): (A.R.) QMS - D1027330, Windchill_Admin_01, A.7
04/05/2021 2:03:26 PM:Publish Complete event dispatched
04/05/2021 2:03:26 PM:remove temp dir: d:\ptc\Windchill_11.2\Windchill\temp\pubtemp\publish2408785347088885520.tmp
