David,
I get the date and time in both WF5 and Creo 2.0. I did a little digging and there is a config option to format the output of these parameters. I'm betting you have it set for your local session of Creo but not on the publisher. Take a look at date_type_parameter_format config option.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS49539
Tom U.
From: David Graham [mailto:david.graham@emhartglass.com]
David,
I used CS20271to extract the required information in a new parameter.
modified_on=extract(PTC_WM_MODIFIED_ON,1,(search(PTC_WM_MODIFIED_ON," "))-1)
I did not test the behaviour during Publishing as yet. Would be interested to know what did you find.
Garun
In Reply to David Graham:
Guys,
When publishing from cad worker PTC_WM_CREATED_ON and PTC_WM_MODIFIED_ON
display as date and time.
In Creo Parametric they display as date only. See images below.
Any way to get them to display as date only when publishing?
Any setting that might do this?
Windchill 10.1 M010
Creo Parametric 2.0 M030
David Graham
Windchill Developer/Administrator
CAx Administrator
Emhart Glass Manufacturing Inc.
Emhart Glass Research Center
123 Great Pond Drive | Windsor, CT 06095 | USA
Telephone | Telefax
Mobile | http://www.emhartglass.com
