Publishing - WT Document
Amirtharaj_K
Hi Guys,
Some WT Document is not published, how we can publish in Windchill with Bulk.
AJ
Hi @Amirtharaj_K
Each context has Utility and there is visualization scheduler as I've mentioned in the first replay.
PetrH
10 REPLIES 10
Hi @Amirtharaj_K
Check WVS Job Scheduler Administration on the Site
PetrH
@HelesicPetrThank you for your bulk approach. Can we publish counts by number? I have over 3 lakhs of data in my Windchill.
Aj
Not sure I follow "publish counts by number". What do you mean? For non-speakers, lakhs=hundred thousand. You can control this by context, you can also pause the queues and let the job generate to see how many would have started if you let it fly.
Thanks for the replay @avillanueva @HelesicPetr
Context-wise how can we pause from the queue, can you elaborate more on this?
Aj
Hi @Amirtharaj_K
You can stop the publish queue in the queue management. This action will stop(pause) the publishing till it is started or server is restarted.
PetrH
But the above scenario is to pause completely right, I can't see context-wise.
Aj
Hi @Amirtharaj_K
You can not stop queue for specific context.
You can just schedule/plan the publishing for specific context.
PetrH
You can just schedule/plan the publishing for a specific context. Can you brief me on this.
AJ
Hi @Amirtharaj_K
PetrH
Thanks for sharing your idea with us. @avillanueva
AJ
