Is there a system setting to turn on publishing a WTPart? The representation is carried froward from the CAD doc just fine when they are all checkout / checkin together. The issue I am seeing is when a WTPart is iterated due to adding additional information to it...then you have to manually click on the viewable on the details page to get the system to create a publish job. This seems like there should be a setting someplace.
Greg
Greg,
You should be able to set up a scheduled publish job (under Preference Management > WVS Job Scheduler Administration) that will execute on a regular basis of your choice (daily, hourly, etc.). You can create a job that will publish all WTParts with no representation (PublishAllPartsNoRepresentation). Would that work for you?
Lori,
I too am in the same situation. However, I have over 4 years of WTParts that at some level will not have representations. If I were to run that, we are talking a lot of jobs for my workers. It is interesting that there isn't a job for (PublishAllLatestPartsNoRepresentation) like there is for EPMDocuments and WTDocuments. Seems like a shortcoming of the Job Scheduler.
Have noticed the same issue also. Rather than manually having to setup a publish job, why cant there be a wvs option to repubilsh wtparts automatically when iterated ?
I set a property that will copy the WTpart rep forward when only the WT is iterated.
I am considering this one too. Still doing the homework to make sure I understand all the use cases and what the results will be. All the details are in the reference document titled "PTC Windchill Visualization Services Guide".
I cannot use the scheduled publishing because there is no check for wt.parts that have no associated epm.document that I am aware of. I have thousands of wt.parts with no associated epm.document and there's no value in filling the publishing queue with that many failed jobs.
