When I check in a Creo drawing that has images embedded on it, the published pdf does not show images (though the pdf shows only Creo entities). Is their a solution I can implement, thanks
As there is only .jpeg embedded images can be seen in pdf, so you need to remove the existing image and rename it to with .jpeg extension. And then try below steps:
