Publishing not happening between set states?
jfrancis
When we change the status of drawing, the worker doesn't publish the drawing. This was not the behavior before and we have to manually click on the thumbnail to create the representation. Could someone  provide me inputs as to where to begin investigating the cause of this issue.
7 REPLIES 7
MikeLockwood
22-Sapphire I
(To:jfrancis)
Here are some related articles CS43043, CS238377, CS229067, CS55087.
Unfortunately it's fairly complex.
Change the publish.republishondocumentchange & publish.republishonepmdocumentchange to true in WVS.propeties.
Shreyas
jfrancis
(To:satre-2)
these properties have been set to true
jfrancis
(To:satre-2)
these properties are set to true and still I face this issue
TomU
(To:jfrancis)
This is how our system is setup (10.2 M030)
Automatically republish on state change:
xconfmanager -s publish.publishonepmdocumentchange=true -t /codebase/WEB-INF/conf/wvs.properties
xconfmanager -s publish.publishondocumentchange=true -t /codebase/WEB-INF/conf/wvs.properties
xconfmanager -s publish.republishonepmdocumentchange=true -t /codebase/WEB-INF/conf/wvs.properties
xconfmanager -s publish.republishondocumentchange=true -t /codebase/WEB-INF/conf/wvs.properties
xconfmanager -s publish.evaluaterulesonrepublish.default=true -t /codebase/WEB-INF/conf/wvs.properties
xconfmanager -p
Did you restart Windchill after making these changes?
jfrancis
(To:jfrancis)
Can publishing be handled through code?
You can use the following code in a Promotion Request workflow in expresion robot in the end.
The code sends the EPM documents to publish queue
try
    //create publisher action -  action string .... M queue
    com.ptc.wvs.common.ui.PublisherAction pa = new com.ptc.wvs.common.ui.PublisherAction(com.ptc.wvs.common.ui.PublisherAction.QUEUEPRIORITY, "M");
    //check all target objects
    wt.fc.QueryResult promotables = wt.maturity.MaturityHelper.getService().getBaselineItems((wt.maturity.PromotionNotice)primaryBusinessObject);
    while (promotables.hasMoreElements())
        Object obj = (Object) promotables.nextElement();
        if (obj instanceof wt.epm.EPMDocument)
            wt.epm.EPMDocument epmdoc = (wt.epm.EPMDocument) obj;
            //Find the latest version of document!!!
            wt.vc.config.ConfigSpec configSpec =  wt.vc.config.ConfigHelper.service.getDefaultConfigSpecFor(wt.epm.EPMDocument.class);
            wt.fc.QueryResult qr =  wt.vc.config.ConfigHelper.service.filteredIterationsOf(epmdoc.getMaster(), configSpec);
            if (qr != null)
                while (qr.hasMoreElements())
                    epmdoc = (wt.epm.EPMDocument)qr.nextElement();
            //check the EPMDocument object
            java.lang.String objRef;
            objRef = wt.fc.ObjectReference.newObjectReference(epmdoc).toString();
            //Create publisher
            com.ptc.wvs.common.ui.Publisher pub = new com.ptc.wvs.common.ui.Publisher();
            //Start publisher
            result = pub.doPublish(false, true, objRef, (wt.vc.config.ConfigSpec) null, (wt.vc.config.ConfigSpec) null, true, null, null,
                    com.ptc.wvs.common.ui.Publisher.EPM, pa.toString(), 0);
        }//if
    }//while
} catch (wt.util.WTException e)
    e.printStackTrace();
