Pull all drawings from server side workplace to local - sub folder cannot be searched?
SC_TK
in Windchill, we have several workspaces. Each workspace has some sub folders.
In the table view, if I want to search "*.drw". I can only see drawings inside my current folder. But nothing from the sub folders.
Did we setup something wrong?
SC_TK
(To:SC_TK)
All right a solution was found. But not as straightforward as I would expected. To get all the drawings. first I selected the General assembly which contained all the models. Then I added this General assembly into my workspace. In the next page, I selected to include all drawings and parts.  All drawings related to the model were saved to local workspace.
I just don't get it why Windchill cannot make the behaviour like Windows explorer.
6 REPLIES 6
jlecoz
(To:SC_TK)
Can you provide us more informations about your use-case?
A user workspace doesn't have sub-folder which is in-line with what you observe.
SC_TK
(To:jlecoz)
Thanks for replying.
Yes, Workspace consists of both local and server side. Local workspace has no sub folder. Just a flat structure. But in common space under the project , there are sub folders on the server side for each workspace.
I need to recreate all the PDFs for all drawings under this workspace. So I tried to pull all of them from server side to my local workspace, but I couldn't find a way to display all them in common space.
avillanueva
23-Emerald I
(To:SC_TK)
Are you using a Product area or a Project?
SC_TK
(To:avillanueva)
We are a company based on projects. Only library parts are in the production area. All the rest are in project.
SC_TK
(To:SC_TK)
jlecoz
(To:SC_TK)
Your solution is the most robust, it identifies all drawing regardless their context location.
Another option would have been to search for all drawing within a project (see vid below)
