Is anybody able to enlighten me to the purpose of the /System domain at product level?
The parent /Private domain at organization level I get (I think). For private products this becomes the parent of /Default domain at product level.
Out of the Box the /System domain is a child of /Private for products, libraries, projects and programs and this is the case regardless if the container is part of a shared team, or marked private or public.
When do the /system rules at product level come into play? To take just one specific example out of the box /System contains a rule to grant all permissions on cabinet to teamMembers, which I can’t explain as the cabinet is associated to the /default domain. Hence it would appear to be redundant.
Excerpts from the WHC
Serves as the default domain for most system administration objects, including queues and life cycle definitions. /System is the default domain of the Administrators group.
The /System domain is not intended for general user business objects.
Check description about other domains here.
Hope this helps.
regards
~Syed
Syed,
That moves me forward a bit thanks.
All the default groups are associated to /User/Unaffiliated with the exception of the
Administrator - /System (site)
ORG ADMIN - /user/{org name} (organization)
This is perhaps not connected with /System (product) though.
I see there is a cabinet in the /System (product) called Administrator and it appears the product level templates at least reside here. I presume therefore that the product context team members need read permissions on the cabinet in /System (product) domain and read access to the templates within so they can initialize template instances. Is this correct?
Darren
