Version: Windchill 12.0
Use Case: Article - CS365094 I followed for QML report for the lists of all the object types in Windchill.
Description:
Hello Team,
I need QML report for the lists of all the object types and usage description in Windchill.
It is unclear what you are asking.
The support article is still visible and the report can be downloaded without any problems.
I have just checked.
Dear Marco_Tosin,
Thank you for your response.
By following Article CS365094, I was able to retrieve all object types along with their internal and display names successfully.
However, what I specifically need is a QML report that includes all object types along with the usage description or purpose of each object type in Windchill.
Kindly help me with this information or guide me to any related reference article.
Best regards,
KR.
There is not a QML with object types and usage description.
Take a look at this article
Hello @KR_1012184030,
It looks like you have some responses from a community champion. If it helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
You can use a report like the one attached to get list of all types and then use the logicalAttributeReport if you info on attribute definition
