Query-Objects case insensitive
rzemmali
11-Garnet
I need to make the query-object search case insensitive. According to the documentation, it is by default. But it my test it does not work. So I put the explicit parameter
<ie:param name="WHERE_CASE_SENSITIVITY" data="FALSE"/>
but the case still sensitive.
Is there further parameters or changes needed?
Thank you.
d_graham
(To:rzemmali)
Your webject syntax looks fine.
Did you try writing a QuerySpec? When you add a SearchCondition to a QuerySpec using the appendWhere() method you can add an additional boolean parameter on the end.
true = case sensitive, false = case insensitive.
I’ve used this many times and it’s always worked as advertised.
The issue was related to another functionnality. Now it works.
Thanks anyway.
