QueryResult doesn't return any rows. QuerySpec has a Column Access Control Item Builder
NTailor
 So I have the following code which is a query that should return me a result of WTDocuments with an identical iba value to an iba value in part.
But I’m not getting any results thought the sql query that the statementspec calls returns a result. Can you help me understand what I am doing wrong and also what is a columnaccesscontrolitembuilder and how do I remove it.
SQL Query from StatementSpec : (yellow I think is the culprit but not sure what that is)
SELECT A0.*,wt.pds.ColumnAccessControlItemBuilder@7e17cd6
FROM wt.doc.WTDocument A0,wt.iba.value.StringValue A1,wt.iba.definition.StringDefinition A2,com.ptc.core.lwc.server.LWCIBAAttDefinition A3
WHERE (A3.idA3A7 = A2.idA2A2) AND (A1.idA3A6 = A2.idA2A2) AND (A1.idA3A4 = A0.idA2A2) AND (A3.name = 'ICS_NUMBER') AND (A1.value IN '1234567') AND (A0.branchIditerationInfo IN (SELECT MAX(A0.branchIditerationInfo) FROM WTDocument A0 WHERE ((A0.idA2A2 = A0.idA2A2))))
SQL query :
SELECT A0.*
FROM WTDocument A0,StringValue A1,StringDefinition A2,LWCIBAAttDefinition A3
CODE :
package ext.itt.audit.configaudit;
import java.io.IOException;
import java.util.ArrayList;
import java.util.Iterator;
import java.util.List;
import com.ptc.core.lwc.server.LWCIBAAttDefinition;
import com.ptc.core.lwc.server.LWCNormalizedObject;
import ext.itt.commonutil.CommonUtils;
import ext.itt.manager.ITTExceptionHandler;
import wt.audit.configaudit.AuditEventRecorder;
import wt.doc.WTDocument;
import wt.epm.EPMDocument;
import wt.events.KeyedEvent;
import wt.fc.ObjectReference;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.fc.WTObject;
import wt.fc.collections.WTArrayList;
import wt.fc.collections.WTCollection;
import wt.iba.definition.StringDefinition;
import wt.iba.value.StringValue;
import wt.part.WTPart;
import wt.pds.StatementSpec;
import wt.query.ClassAttribute;
import wt.query.QueryException;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.query.SubSelectExpression;
import wt.util.WTException;
import wt.util.WTPropertyVetoException;
public class SecurityLabelPropagationAuditEventListener implements AuditEventRecorder {
       @Override
       public void recordMultiObjectEvent(KeyedEvent keyedevent, WTCollection wtcollection) throws WTException {
              System.out.println("KeyedEvent: " + keyedevent.getEventType() + " | " + keyedevent.getEventKey());
              System.out.println("WTCollection.size() : " + wtcollection.size());
              Iterator wtcollection_iterator = wtcollection.iterator();
              WTArrayList arrList = new WTArrayList();
              while (wtcollection_iterator.hasNext()) {
                     Persistable p = (Persistable) ((ObjectReference) wtcollection_iterator.next()).getObject();
                     System.out.println("Persistable Info : " + p.getPersistInfo().getObjectIdentifier());
                     if (p instanceof WTPart) {
                           // eligible for pdf stamping
                           arrList.add((WTPart) p);
                     } else {
                           continue;
              if (!arrList.isEmpty()) {
                     try {
                           propogateSecurityLabels(arrList);
                     } catch (WTPropertyVetoException e) {
                           // TODO Auto-generated catch block
                           e.printStackTrace();
                     } catch (IOException e) {
                     } catch (ITTExceptionHandler e) {
              } else {
                     System.out.println("No persistable found from where can propogate security labels");
       @Override
       public void recordEvent(KeyedEvent keyedevent) throws WTException {
    public void propogateSecurityLabels(WTArrayList docList) throws WTException, WTPropertyVetoException, IOException, ITTExceptionHandler {
        //logger.debug("Entering ********propogateSecurityLabels********");
        System.out.println("Entering propogateSecurityLabels");
        CommonUtils cu = new CommonUtils();
        if (docList.size()!=0) {
           Iterator iterator = docList.iterator();
           while(iterator.hasNext()) {
              Persistable perst;
              Object object = iterator.next();
              if (object instanceof ObjectReference) {
                 ObjectReference obj_ref = (ObjectReference)object;
                 perst = obj_ref.getObject();
                 WTPart part = (WTPart) perst;
                 LWCNormalizedObject obj = new LWCNormalizedObject(perst, null, java.util.Locale.US, newcom.ptc.core.meta.common.DisplayOperationIdentifier());
                 /* Get value of IBAName soft attribute */
                 obj.load("ICS_NUMBER");
                 String ibaValue = (java.lang.String) obj.get("ICS_NUMBER");
                 //String ibaValue = cu.getIbaValue("ICS_NUMBER", part);
                 System.out.println("ibaValue : " + ibaValue);
                 // get all WTDocuments with an iba of ics and the value that wtpart has
                 List<WTObject> docs = fetchAllDocumentsWithIBAValue(WTDocument.class, "ICS_NUMBER", ibaValue, false );
                 System.out.println("doc size: " + docs.size());
                 // update their security labels
                 for (WTObject doc : docs) {
                    new CommonUtils().setSecurityLabels((WTDocument) doc, cu.getSecurityLabels(part) );
                 List<WTObject> epmDocs = fetchAllDocumentsWithIBAValue(EPMDocument.class, "ICS_NUMBER", ibaValue, false);
                 System.out.println("epmdoc size: " + epmDocs.size());
                    new CommonUtils().setSecurityLabels((EPMDocument) doc, cu.getSecurityLabels(part) );
        System.out.println("Exiting propogateSecurityLabels");
        //logger.debug("Leaving propogateSecurityLabels");
     * Query Database
     * Find all documents with an ICS Number that is linked to WTPart
     * SQL Query :
     * Select doc.ida2a2, sv.value, lwc.name
              FROM WTDocument doc, StringValue sv, StringDefinition sd, LWCIBAAttDefinition lwc
              WHERE
              doc.latestiterationinfo=1
              and
              lwc.ida3a7 = sd.ida2a2
              and
              sv.ida3a6 = sd.ida2a2
              and
              sv.ida3a4 = doc.ida2a2
              and
              lwc.name='ICS_NUMBER'
              and
              sv.value='000466990'
              and
              doc.branchiditerationinfo in
              (select MAX(doc2.branchiditerationinfo) from wtdocument doc2 where doc.ida2a2 = doc2.ida2a2)
    public static List<WTObject> fetchAllDocumentsWithIBAValue(Class documentClass, String ibaName, StringvalueToSearchFor, boolean grabLatest) throws WTException {
       QuerySpec qs = new QuerySpec(documentClass);
       int idxDocument = 0;
       int idxStringValue = qs.addClassList(StringValue.class, false);
       int idxStringDefinition = qs.addClassList(StringDefinition.class, false);
       int idxLWCIBAAttDefinition = qs.addClassList(LWCIBAAttDefinition.class, false);
       if (grabLatest) {
              qs.appendWhere(new SearchCondition(documentClass, "iterationInfo.latest", SearchCondition.IS_TRUE), newint[] {idxDocument});
              qs.appendAnd();
       qs.appendWhere(new SearchCondition(LWCIBAAttDefinition.class, "ibaReference.key.id", StringDefinition.class,"thePersistInfo.theObjectIdentifier.id"), new int[] {idxLWCIBAAttDefinition, idxStringDefinition});
       qs.appendAnd();
       qs.appendWhere(new SearchCondition(StringValue.class, "definitionReference.key.id"  , StringDefinition.class, "thePersistInfo.theObjectIdentifier.id" ), new int[] {idxStringValue, idxStringDefinition});
       qs.appendAnd();
       qs.appendWhere(new SearchCondition(StringValue.class, "theIBAHolderReference.key.id", documentClass,"thePersistInfo.theObjectIdentifier.id"), new int[] {idxStringValue, idxDocument});
       qs.appendAnd();
       qs.appendWhere(new SearchCondition(LWCIBAAttDefinition.class, "name", SearchCondition.EQUAL, ibaName), new int[] {idxLWCIBAAttDefinition});
       qs.appendAnd();
       qs.appendWhere(new SearchCondition(StringValue.class, "value", SearchCondition.IN, valueToSearchFor), new int[] {idxStringValue});
       qs.appendAnd();
       qs.appendWhere(new SearchCondition(new ClassAttribute(documentClass, "iterationInfo.branchId"), SearchCondition.IN,
                    new SubSelectExpression(getMAXBranchID(documentClass, idxDocument))), new int[] {idxDocument});
       qs.setAdvancedQueryEnabled(true);
       QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs);
       System.out.println("qs:" + qs.toString());
       List<WTObject> documents = new ArrayList<WTObject>();
       while (qr.hasMoreElements()) {
              Object nextElement = qr.nextElement();
              if (nextElement instanceof WTObject) {
                    documents.add((WTObject) nextElement);
       return documents;
    // (select MAX(doc2.branchiditerationinfo) from wtdocument doc2 where doc.ida2a2 = doc2.ida2a2)
    public static QuerySpec getMAXBranchID(Class documentClass, int indexForSelectDocClass) throws QueryException {
       QuerySpec qs2 = new QuerySpec();
       int idxDoc2 = qs2.appendClassList(documentClass, false);
       qs2.appendSelect(wt.query.SQLFunction.newSQLFunction(wt.query.SQLFunction.MAXIMUM, newClassAttribute(documentClass, "iterationInfo.branchId" )), new int[] {idxDoc2}, false);
       qs2.appendWhere(new SearchCondition(documentClass, "thePersistInfo.theObjectIdentifier.id", documentClass,"thePersistInfo.theObjectIdentifier.id"), new int[] {idxDoc2, indexForSelectDocClass});
       return qs2;
NTailor
(To:NTailor)
So apprently you want to use
QueryResult qr = PersistenceServerHelper.manager.query((StatementSpec) qs);
to remove the access restrictions and having a columnaccesscontrolitembuilder show up
dsolat1
6-Contributor
(To:NTailor)
How can we write a query if we need to check if iba1 = specificValue also if iba2 = specificValue.
