Question about Frames in Windchill 10.1
frodriguez-4
2-Explorer
How do we control Frames size in the event manager in Windchill 10.1 using Creo 2 m70 on the client side?
7 REPLIES 7
TomU
(To:frodriguez-4)
It's a Windchill user preference setting.
[cid:image001.png@01CFBD55.6E86EDC0]
[cid:image002.png@01CFBD55.6E86EDC0]
I set that, but the users have to do anything on their end or do we have to reset Windchill in order for it to take effect . As on the client side they are generating more frames than what is set.
Thanks in advance.
TomU
(To:frodriguez-4)
As far as I know it takes effect immediately.
The frames are only the events with the little paper icon. Are you sure you're getting more frames than the target value?
[cid:image001.png@01CFBD56.DD254C80]
Tom U.
TomU
(To:frodriguez-4)
I just did a quick test. You have to restart Creo to have the setting take effect.
Tom U.
Ok, I will have our engineer's test it out in the AM tomorrow and post back my findings, thanks for the quick response.
Francisco Rodriguez | Network Systems Administrator | ASCO Power Switching and Controls
Emerson Network Power | 50 Hanover Road | Florham Park, NJ 07932
T 1-973-966-2072 | M 1-973-524-0149 | TF 1-800-800-ASCO
Frankie.Rodriguez@emerson.com<">mailto:Frankie.Rodriguez@emerson.com>
www.EmersonNetworkPower.com<">http://www.EmersonNetworkPower.com> www.AscoAPU.com<">http://www.AscoAPU.com>
Yes to your question below.
Maybe I don't really understand Frames, but I've never found them useful. When I first looked at frames back in 9.1 here are some of the issues I found.
* In Intralink 3.x stepping back was liner each frame you applied stepped you back in time
* If you pick "Apply previous Frame" multiple times in Windchill, you're not stepping back in time. Your toggling between two frames.
* If you go to the event manager to apply frames you will notice not everything you do creates a frame.
* There is no initial frame created when you open a file from your workspace.
* The event manager shows frames from multiple days. What are your chances of successfully applying a frame from a previous day?
* Also notice that you can't tell from the event manager what object & workspace that frame relates to. You would have to look at the information on that event to tell what object it relates to.
* What happens when you mistakenly apply a frame from workspace A to workspace B????
After playing around with it when it first came out in 9.1, I said no thanks and haven't looked at it again.
Like I said, perhaps I don't understand how to use frames. I'm open to be enlightened.
If you have a good tutorial showing how you would use this in real life, please share.
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
________________________________
