RE: Getting Windows Pro/E and ILink Clients talking<br /> to each other
Level 1
I noticed you said Pro/E was installed in "program files" directory. If
this is true you must surround the path in the ilink.bat file with ".
Andrew Montgomery
Designer / Engineering Systems Administrator
ph. 815-673-6048
fax 443-432-0467
Vactor / Guzzler Manufacturing
Federal Signal Corp.
