REACH June 2015 SVHC - Verdict error in WPA
rks
Reach SVHC June 2015 release added two substances for which CAS number is not defined unlike the other substances.
Currently WPA is checking for the string 5-sec-butyl-2-(2,4-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [1], 5-sec-butyl-2-(4,6-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [2][covering any of the individual stereoisomers of [1] and [2] or any combination thereof] to determine a PASS or FAIL for the substance.
ECHA as part of the REACH notification has given the below clarification.
  Candidate list entry “5-sec-butyl-2-(2,4-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [1], 5-sec-butyl-2-(4,6-dimethylcyclohex-3-en-1-yl)-5-methyl-1,3-dioxane [2] [covering any of the individual stereoisomers of [1] and [2] or any combination thereof]”, is a group entry covering substance [1], substance [2], any of the individual stereoisomers of substance [1], any of the individual stereoisomers of substance [2], and any combinations of these substances. Therefore, if a part contains only substance [1] or only substance [2], these  still fall within this group entry and the Candidate list obligations
apply.
Section 1.2 of the corresponding supporting document provides examples of substances belonging to this group for which a registration or C&L notification is available. The supporting document for this Candidate list entry is available at: http://echa.europa.eu/documents/10162/b33a9276-9a0e-4720-87ce-76dc651a6ee6
   Table 2 of the same supporting document section provides a non-exhaustive list of examples of substances covered by this group entry.
Suggestion
Based on the above logic, system should be doing the check based on [1] OR [2] and by the presence of ANY one of the substance mentioned in the ECHA release and NOT by the enitir string alone
0 REPLIES 0
