REPEAT REGION BOM ISSUE
ctorti
REPEAT REAGION BOM IN DRAWING CHECKED IN RECENTLY HAS ISSUE. ONE COMPONENT OF SUBASSEMBLY IS IGNORED . CREO 4.0 AND WINDCHILL 10.2
5 REPLIES 5
avillanueva
23-Emerald I
(To:ctorti)
Version you are using should not matter. This has been stable for some time. Not sure why you are posting to Windchill group since this looks like a Creo specific issue....unless...you are seeing it correct in Creo but when you view through Creo View from Windchill, you see it missing. Which is it?
ctorti
(To:avillanueva)
I suppose issue could be related to windchill because I have “recently” checkedin the drawing. I could be it is only issue with Creo Parametric. I am opening a drw drawing in Creo Parametric and 3D model is correct but repear region table in drawing is missing one component and no filter in table is on.
avillanueva
23-Emerald I
(To:ctorti)
You can diagnose this by adding to workspace and looking at "latest" vs "as-stored" for the drawing. Look closely at the iterations of the assembly that its asking for. Do this is a clean and empty workspace. This eliminates any local modifications of the assembly that might appear in your current workspace. Lastly, I do not deal with drawings much but try rebuilding or creating a new repeat region table?
ctorti
(To:avillanueva)
  1. Look closely at the iterations of the assembly that its asking for. => Done (Assembly drawing saved in March while sub-assembly saved in April of this year so it is normal that different version of sub-assembly is required)) issue exists in both worspaces.
  2. try rebuilding or creating a new repeat region table? Yes.
  3. We are checking and it appears issue related to simplified representation.
avillanueva
23-Emerald I
(To:ctorti)
That make sense if related to simp rep. I would discount Windchill as being the cause here.
