Re : Re : Database error - invalid name pattern
Highlighted
Newbie
Did you create the same Base Distinguished Name (for aphelion) during the target PDMLink installation...
Ps: you should check the "WindchillRehostGuide.pdf" procedure....
- Nicolas
----- Message d'origine ----
De : Prathap <->
À : -
Envoyé le : Lundi, 28 Juillet 2008, 19h50mn 25s
Objet : [solutions] - RE: Re : Database error - invalid name pattern
Hi Nicolas,
Thanks for the hint. I exported the database and ldap information at the same time from the source server and they seem to have same user accounts details in both places.
Prathap
Highlighted
SUMMARY : Database error - invalid name pattern
Thanks for all your input.
This issue happened when I tried to import the same database into 2 separate instances of the same oracle server. The import command gave errors while trying to create some tables like TABLE_OF_VARCHAR2, TABLE_OF_DATE, INSTANCE_ROW etc. All these tables have unique ids which have to be regenerated by running the actual SQL rather than importing. I collected all the SQL that failed and ran it after the import to create those tables. Check the attached sql file for the complete list of tables which are failed.
- Nicolas
De : Prathap
À : -
Hi Nicolas,
Prathap
