As per the original Post.
Can you, or anyone else, verify if this works in WC 12+?
Thanks, Lawrence
@LawrenceS (and @LoriSood),
These same steps are documented in CS41798. I can confirm that following them will allow folders to be searched in Windchill 12.1.1.0. I did have to change the property mentioned in the 'Note' section. Without this the search results were always zero for any folder name.
@TomU , BTW, thanks also for the CS reference! That makes it even more straightforward.
I just want to verify that we implemented this in our test and then the Production environment. It worked seamlessly and we are now enjoying the new capability!
Thanks again!
