As per the original post.
Facing the same problem, but it says hidden by SetStateURLActionDelegate. Can you guide on this issue?
Hi @Srivalli
It depends where the function is located. Workspace, Commonspace Folder, Changeobject info page
All motioned locations are allowed by the SetState delegate.
Provide more information.
Screenshot, also you can try to set logger SetStateActionDelegate to a debug mode to investigate a root case.
PetrH
