Read only users - publish on demand
davehaigh
I have some users that have read only rights to ProE objects in PDMLink.
If the object does not have a viewable, I'd like to have them just click on the icon to create the viewable so they can see it after the publishing is done.
However it appears if they don't have modify rights to the parent object, that the viewable will not get attached.
Is our system set up badly?
Is there a way around this problem?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
I do not remember setting up special rights for this but I do have a
user setup to publish items using a workspace. They handle all
publishing jobs. Are you getting a specific ACL exception in the MS or
BSMS log?
