Real Number Attributes
Regular Member
We just installed Intralink 3.4 this week and I have been assigned as our
administrator. I have spent some time learning the fundamentals and adding
our company parameters into Intralink as object attributes but cannot add
weight, since the choices for attribute type are String, Integer, Float,
Date, and Boolean (doesn't have Real Number.) I tried making an integer
parameter in a part called LBS with a relation to the part mass, however in
doing so Pro/E changes the LBS parameter from an integer to a real number.
How can I get our part and assembly weights entered into Intralink?
Thank you,
Anthony Troupe
Designer
MGS Incorporated
178 Muddy Creek Church Road
Denver PA 17517
Re: Real Number Attributes
Anthony,
You should make that LBS Parameter a Float attribute type and not integer
in Intralink. Mass values are float not integer.
Rey
