I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS07
Running the reassign life cycle utility and I am getting skipped items.
SKIP REASSIGN: Object's current LC state is not available in target LC for wt.doc.WTDocument:67656969
ERROR MESSAGE: null
Read the following article - "Running wt.lifecycle.utility.doer.ReassignDoer causes "SKIP REASSIGN: No open process associated to object: <objectReference>" in Windchill 10.0": https://www.ptc.com/en/support/article/cs32843
Hello Billy_Johnson,
I’m Charles from PTC Technical Support in Europe, I will be assisting you with this question ‘Reassign Life Cycle error SKIP REASSIGN’.
Has the knowledge database article cs32843 been helpful somehohow?
KR,
Charles.
May I ask few question here
What command did you use? is this java wt.lifecycle.utility.reassign.LCReassignUtility ?
Are you in the scenario of updating an object’s lifecycle template to one that does not contain its current state?
Can you retry with detailedLogging=true and set below logger from Windchill shell
windchill wt.util.jmx.SetLogLevel wt.lifecycle DEBUG
reproduce the use-case with the error message, then send me (email=cgautier@ptc.com) the MethodServer log and pinpoint the timestamp and the login used.
KR,
Charles.
Hello cguatier, I apologize for the delay in my response. I set the parameters you listed above and I have the same error as before.
Please find related error(s) in the background method server log and provide here - we may be able to get more clues.
