Sean Sullivan
Velcon Filters LLC
CAD Administrator / Product Development Engineer
Jamie,
I just finished writing this utility for another customer. I'll provide it to you in a private email. It should do everything you're looking for in a nice bulk fashion. You can modify the code as you see fit for your own needs. It will let you select the current lifecycle template, a target container and a object type, from there it will search and find all the objects that match those characteristics and it will then reassign the lifecycle template to the latest iteration of a template that you choose. I tested it last night on 20k parts and it only took 45 seconds to do all the reassignments. Probably a lot faster than some of your other alternatives.
Best Regards,
Steve
Steve, is there any place where this kind of solution is made available to the whole group? If so, is it possible for us to submit our own solutions to such a site?
-Thomas Busch
Thomas,
I offered up the solution to everyone directly that asked so that I could pass along the terms of support. Basically with the tool I wrote everyone that received it acknowledged that they received it as custom code that they're responsible for. PTC Tech Support would certainly help with the tool as a customization type of call, but they wouldn't treat it as an OOTB issue as far as bugs go. And that's technically where most of the issues comes up with this topic.
There certainly can be ways for the community at large to create a PTCForge style library of components. Since many components built from one developer at Company A to the next developer from Company B are potentially overlapping there are some potential conflicts that would need to be managed and evaluated from one company to the next. As far as support goes, it would need to be something that was community driven as well since it would be very challenging for PTC to manage not only our normal release streams but any custom code support would be particularly challenging.
I believe it would be a worthwhile discussion with PTC Product Management. As a community driven activity it's possibly worth the discussion with the PTC/User board on how much support (primarily hosting) they would want to manage to allow the user community the ability to share their contributions. I can certainly ask around and see what some of our own internal intentions are with some of these ideas.
Steve
Steve,
In the process of migratingfrom 8.0 to 9.1, I know all my process are going to fail unless I can switch objects to the latest iteration of their lifecycles. Is it possible for you to send me the utility you were talking about in this post ?
TIA,
Vincent Quesnoit
In Reply to Steve Dertien:
Jamie,
Best Regards,
Steve
