Reassignment of ECN tasks en masse
Highlighted
Opal
Hey,
Does anyone know of a way to reassign ECN tasks from one individual to another person without having to open each and every ECN and do it manually? Something along the lines of replace team member in ProjectLink would be great.
Windchill 8.0 m050
I have about 45 ECN's to change, and was hoping there would be an easier way...
- marc
Highlighted
SUMMARY: Reassignment of ECN tasks en masse
Thanks to Jim Pauletto for the solution to my problem.
1. Select Product or Library Tab, then Assignments Sub-Tab
2. Select Assignments to be reassigned
3. Select <reassign> icon
See attached screenshot.
- marc
CAD / PDM Manager
Highlighted
Do you want to do it with SQL or code?
Is this a more then one time thing?
If you know the user's logon name - you can find the user unique identifier
for the db and cross it with the workitem db table. You can do an update or
reassignment by swapping out the user's id.
As admin, you might be able to look at assignment sub tab and reassign them
from there one by one.
Highlighted
hi,
the new ext.tools on pdmteam (the one available to premium users) has a
couple of workflow related jsp pages - one of them lets you find all
tasks of a user and reassign them (all or selectively) to another user.
cheers, martin
Highlighted
hi,
(others find "dead" workflows, those without running tasks or robots -
or search processes with certain values in their variables ...)
cheers, martin
