Rebranding Windchill
tstacy
Hi.
I'm trying to find out how to change the image at the top of the Windchill UI. I need to "rebrand" the header in Windchill to match my user community colors and images. I did this in our V9.1 environment, but haven't found out how to do this in V10.2 yet. Also, I would like to customize the colors used by the browser.
Not the right shade of blue for our customers. Something like this:
Anyone have an idea where I need to look?
TomU
(To:tstacy)
Take a look at Customizing UI Branding.
Something else you can do is manually alter the colors in some key files. (You won't find this in the documentation.) Here is a picture of what my test system looks like and the files I changed to get there. (This is for 10.2)
codebase\netmarkets\themes\windchill\Header\
codebase\netmarkets\themes\windchill\navigator\
codebase\netmarkets\themes\windchill\panel\
16 REPLIES 16
tstacy
(To:tstacy)
TomU
(To:tstacy)
BuddyHudson
(To:TomU)
Hey Tom,
How did you get the "Windchill Test System" to come up? I have looked at the files you posted and they don't pertain to this text on your pic.
Thanks in advance,
Buddy Hudson
TomU
(To:BuddyHudson)
Sorry about that. The concept is covered in "System Banner Alert Message".
Basically you add a single line to begin_custom.jspf and then put something in banner.txt.
My banner.txt file contains the following:
<style>
#bannerID{
font-size:15px;
cursor:default;
float:left;
clear:both;
position:absolute;
margin:2px 170px;
padding:3px;
top:0px;
z-index:1000;
</style>
<span id="bannerID">
<!-- Banner begins here -->
<b><a style="color:#FFFFFF">Windchill 10.2 Test System</a></b>
<!-- Banner ends here -->
</span>
<script type="text/javascript">
//START--The tooltip for the top banner
Ext.onReady(function(){
Ext.QuickTips.init();
new Ext.ToolTip({
target: 'bannerID',
html: '10.2 M010 Test (05/23/2014)'
//END--The tooltip for the top banner
</script>
BuddyHudson
(To:TomU)
Awesome! Works great thanks again Tom!
Buddy
JarrettOberg
(To:TomU)
Hey Tom,
This is an excellent example and a really good looking windchill.
Thanks for providing that!!
BenPerry
(To:TomU)
Tom Uminn‌, do you find that the background of the navigator is still blue when you expand it? I have a screenshot below.
FYI...I really like your method. Grab these files and just open in IrfanView. Select Image > Swap > and then one of the options there. The dark pink is RGB -> GBR. Very simple but very effective.
TomU
(To:BenPerry)
Here is the list of the folders and files I'm changing:
Header
navigator
panel
I automatically replace these after each rehost with these commands:
copy /y E:\Stage\Dev_Changes\Header\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\Header\*.*
copy /y E:\Stage\Dev_Changes\navigator\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\navigator\*.*
copy /y E:\Stage\Dev_Changes\panel\*.* E:\ptc\Windchill_10.2\Windchill\codebase\netmarkets\themes\windchill\panel\*.*
BenPerry
(To:TomU)
Ah, I see! BG_stripe_tile_nav.png I actually can't swap RGB with that one, presumably because it is so small. 4px x 4px. Not in IrfanView anyway.
TomU
(To:BenPerry)
I vaguely remember having to change a couple of them in paint. Looks like maybe all of the panel *tile* images.
aacciano3
(To:TomU)
@TomU
Have you tried this on 11 or 11.1?
Any luck?
Thanks!
TomU
(To:aacciano3)
I had not until 15 minutes ago.  😉
Windchill 11.0 doesn't use images for the background so changing it is actually easier.  Just alter a few values in the main css file:  <Windchill Home>\codebase\netmarkets\themes\windchill\xtheme-windchill.css
For example, try changing the background colors on lines 3188, 3193, and 3288 to #FFFF00 (yellow):
Changing these three values will make Windchill look like this:
aacciano3
(To:TomU)
Thank you Tom!
BenLoosli
(To:TomU)
I changed the background color on line 3188 to a dark blue (#0000FF).
When I open Windchill in Bing, it did not change the color, but in IE and Chrome it did.
TomU
(To:BenLoosli)
Bing is a search engine...  Do you mean Microsoft Edge?  My guess is that the CSS is cached.  Try reloading the page while pressing F5, CTRL + F5, SHIFT + F5, etc.
BenLoosli
(To:TomU)
Yes Edge!
Ctrl-F5 did it.
