How to recover (Undo) deleted workspace in Windchill 10.2. I accidentally deleted workspace that had 1 week worth work.
Any suggestions are welcome .
System should not allow you to delete a workspace that has checked out content. Are those item new items in workspace? Did you do a upload to server?
Thank you
Binesh Kumar
Barry Wehmiller
I had no checked out objects. I did not upload on server.
There is a recovery tool available from Ron Thellan somewhere on this site that may help.
There have been other posts about this in the past month.
If you have not run remove unreferenced files, you may be able to recover your files by running that command with the option to move the files to the unreferenced folder and then search the file headers for your files.
Thank you all for helping me out with this. I was able to recover all the assemblies and drawing with use of the tool.
