I am a little confused with the rehosting guide on the adapter. On page 122 under target.adapter.name, it says "The adapter on the target system takes its name from name of the adapter on the source system. Specify the source system name in this rehosting property."
So if my adapter name is the following: com.<company_network>.<source_server>.Windchill, will my target.adapter.name.1=com.<company_network>.<source_server>.Windchill or do I put in the target server name? If I leave the source name, when/how does that change?
Their directions seem backwards to me with what everything else tells me to do in other sections for target.
Thank you,
Brian
Not sure why it's working, but I do have the source adapter names listed for the names, but the properties changed to match the target. However after rehost the adapters all have their names changed to match the target system.
Brian,
Did you observe the same behavior? It seems like the adapters get copied from one system to another with their previous name. I think InfoEngine might handle renaming them and then IEAdapter handles changing their properties. There does seem to be some weirdness between what is documented and how the IEAdapter task actually works. It says to only list things you want to change, but I'm having issues if I don't list everything. I'm still trying to figure out how to get the Active Directory adapter to copy over correctly. Did you get it to work?
Tom,
Yes I saw the same thing. It just gets confusing when they expect the target server name for everything else that is named target. It seems that should have been named source. Everything seemed to change correctly. However I still cannot login via our corporate LDAP.
Brian,
I have managed to get everything related to the corporate LDAP adapter to properly rehost except for the password. After repeating this process many times (virtual machines with snapshots are wonderful!), I was able to determine several things:
xconfmanager -s "mapcredentials.admin.adapters=com.tm.Ldap^cn=Manager^password_goes_here"
xconfmanager --add "mapcredentials.admin.adapters=com.tm.EnterpriseLdap^cn=Manager^password_goes_here"
xconfmanager --add "mapcredentials.admin.adapters=com.tm.ActiveDirectory^cn=Windchill,ou=Users,dc=tm,dc=com^password_goes_here"
xconfmanager -p
Tom,
Sorry, I have been on vacation the last couple of days and the tech support guy got with me late on the day before taking vacation so I haven't had time to post here. The support guy pointed me with those same settings. He also pointed me to the settings on the JNDI Adapter. When you edit the adapter, it is wrong in the Provider Url, as it has set it to the target machine instead of keeping it with the correct LDAP server. Make sure to change this to the same as on your production server. Also make sure that the Search Base is the same. You can just copy and past both of these. Once we did all of these things it finally connects. He said that they know about this issue but he didn't know when it will be fixed.
Just wanted to close the loop on this. Rehost Tool 2.0 incorrectly changes the passwords on additional adapters. See the following article and SPR.
