Rehosting 11.0 m030 renaming FV path
slhumphrey
8-Gravel
I am doing a rehost and the file vault paths are changing.  I don't want it to copy vault data (we have already created stub files in the new location). Can I not just specify the fv path (source and target) but not copy the vault files? Here's what I would have in the rehost.properties file.
target.fv.required=true
source.fv.hostname.0= source.intranet.com
target.fv.hostname.0= target.intranet.com
source.fv.path.0=\\source\Windchill_Vaults
#staging.fv.path.0=E:\vaultStaging\vault1
target.fv.path.0=E:\Windchill_Vaults
BenLoosli
(To:slhumphrey)
Not sure
I left them on mine incase the code was looking for a numeric sequence number and started the count at 0.
8 REPLIES 8
BenLoosli
(To:slhumphrey)
Are you rehosting between a Unix box and Windows?
The vault locations indicate that you are.
Rehost does not support moving between operating systems.
Hi Ben,
No we have a nfs mount reference on the production system and a local drive on the target system.  Both are windows servers.
Sandra
BenLoosli
(To:slhumphrey)
Sandra,
That should work. I always copy my vaults over before running the rehost.
Ben
I have already copied the files over.  So when I make the following configurations, it will update the database with the target fv path without trying to copy any of the vault files?
source.fv.hostname.0= production.intranet.com
target.fv.hostname.0= dev.intranet.com
#target.fv.required=false
source.fv.path.0=\\NFS_server\Windchill_Vaults
BenLoosli
(To:slhumphrey)
Yes
It will only update the pointers in the DB to the new hostname and vault location.
And since I only have 1 source and 1 target, do I need to put the .0 on the hostname and path variables?
Sandra
BenLoosli
(To:slhumphrey)
Not sure
Ok. Thank you for your help!
Sandra
