Our current production system is 9.1 M050(migrated from 8.0) using Aphelion. I wanted to do a rehost of this system, so I did a fresh install of 9.1, and have hit stumbling block. The procedures in the 9.1 Rehost Guide says to export my users and ou=pendingUsers from the Source system and do an import to the Target system. Remembering what I had to do for the migration, should I back up the Target system's target config branches first? Do I do a full LDAP export from the Source system? Are the utilities the same under 9.1 as they were for 8.0? Just wondering if anyone else has done a rehost under 9.1 and could clarify a few things that the Rehost Guide seems to gloss over. Thanks!
Send lawyers, guns, and money...the sh!t has hit the fan!
